Activity Forums Apple Final Cut Pro Legacy Mpeg2 question
  • Posted by Anton Shu on August 6, 2008 at 2:48 pm
    Hello everyone,
    Is it possible to export mpeg2 file via compressor 2 with video bitrate of 15 mbps?
    My video files are DVPAL res. (720×576 4:3 25 fps)
    The way I do such a conversion is : I`m exporting AVI without compression and via PC tmpeg encoder exporting the mpeg2 with 15mbps, I`m sure this is wrong way and very time consuming.
    Please share your experience
    Ed Dooley replied 18 years, 1 month ago 4 Members · 11 Replies
  • 11 Replies
  • David Roth weiss
    August 6, 2008 at 3:11 pm
    Yes, that is a very inefficient workflow. Almost anything is possible using Compressor, but what is the objective you’re trying to accomplish with the 15mbps MPEG2? Are you trying to make MPEG2 transport stream for delivery?
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • Ed Dooley
    August 6, 2008 at 3:53 pm
    Are you sure anything is possible with Compressor 2? I think the highest data rate you can get from SD PAL is 9Mbps. You can get up to 29Mbps with HD, but I don’t know how to do that with SD.
    I’d love to be proven wrong though. 🙂
    Ed
    [David Roth Weiss] “Yes, that is a very inefficient workflow. Almost anything is possible using Compressor, but what is the objective you’re trying to accomplish with the 15mbps MPEG2? Are you trying to make MPEG2 transport stream for delivery? “
    [Anton Shu] “Hello everyone,
  • David Roth weiss
    August 6, 2008 at 4:17 pm
    [Ed Dooley] “I’d love to be proven wrong though. 🙂 “
    Come on Ed, when will you ever learn, I’m always up for that challenge.
    See page 185 in the Compressor manual, re: stream usage (i.e. creating an MPEG2 transport stream).
    Stream Usage
    Choosing a setting from the Stream Usage pop-up menu ensures the encoded MPEG-2
    stream will be suitable for how you intend to use it. The options in the Stream Usage
    pop-up menu include:
    Generic: The Generic option allows you complete access to all the MPEG-2 settings.
    This is the only option that supports the MPEG-2 640 x 480 video format in addition
    to the SD and HD video formats. It is also the only option that supports creating
    transport and program streams. It supports the complete bit rate range of 2.0 Mbps
    to 40.0 Mbps.
    David Roth Weiss
    Director/Editor
    Los Angeles
  • Ed Dooley
    August 6, 2008 at 4:26 pm
    I guess I’ll never learn. 🙂
    But…. He is talking about Compressor 2. I only have the on-line manual for Compressor 2 and there’s nothing called Stream Usage anywhere in the index or from a search (page 185 in the C2 manual is about filters). The only option I’ve ever found about Transport Streams is the button for muxing. Am I totally missing it, or are you talking about Compressor 3 (which he isn’t)?
    Ed
    [David Roth Weiss] “d Dooley] “I’d love to be proven wrong though. 🙂 ”
    Stream Usage
    to 40.0 Mbps. “
  • David Roth weiss
    August 6, 2008 at 4:56 pm
    [Ed Dooley] “Am I totally missing it, or are you talking about Compressor 3 (which he isn’t)?”
    Drats!!! I failed to notice that minor detail.
    Well, anyone still using FCS1 is just plain silly in my opinion anyway…
    David Roth Weiss
    Director/Editor
    Los Angeles
  • Ed Dooley
    August 6, 2008 at 5:01 pm
    It’s OK David, I’m not keeping score. 🙂 (When will you ever learn, indeed!)
    Ed
  • Chris Borjis
    August 6, 2008 at 5:02 pm
    [David Roth Weiss] “Generic: The Generic option allows you complete access to all the MPEG-2 settings.”
    David it gives more access but only a little more for the bitrate it seems.
    I want the setting to allow me to set the GOP to whatever number I want and be able to manually configure the mpeg1 layer2 audio settings for an mpeg program stream. (for DGS delivery)
    is that possible?
  • David Roth weiss
    August 6, 2008 at 5:21 pm
    GOP has only limited manual settings and Audio can be set for mpeg1 layer2 audio settings for an mpeg program stream, but I don’t see any specifics for additional manual settings.
    David Roth Weiss
    Director/Editor
    Los Angeles
  • Chris Borjis
    August 6, 2008 at 5:22 pm
    wow, apparently one can make a copy of a preset and edit it with text edit to get whatever settings you want, even if they are grayed out in compressor.
    some people at the apple forum have successfully done it.
    cool!
  • Anton Shu
    August 7, 2008 at 10:05 am
    Thanks for the quick response!
    [David Roth Weiss] “Stream Usage
    to 40.0 Mbps. “
    I can`t find such an option where to choose a Stream Usage, where is it located?
    or there is no such in compressor 2?
    Thank You
