Activity Forums Adobe Premiere Pro MPEG2 file is fine but DVD has moire
  • MPEG2 file is fine but DVD has moire
    Posted by Dave Rogers on December 12, 2010 at 2:06 pm
    I have produced a MPEG2 file in premiere that looks fine on my monitor but when I convert it to a DVD using ConvertXtoDVD the video has moire ( flickering ) in several places
    Why would the MPEG2 be fine but the DVD be bad ?
    If I saw the moire in the MPEG2 I would understand that the video may need to be blurred slightly but it looks fine.
    Thanks for any advice
    Dave Rogers replied 15 years, 9 months ago 3 Members · 5 Replies
  • Ann Bens
    December 12, 2010 at 6:40 pm
    Encode straight to mpeg2-dvd or let Encore do the encoding and burning.
  • Dave Rogers
    December 13, 2010 at 6:05 pm
    Thanks for the advice but it still has the moire problem when exported to MPEG2-DVD with export settings high eg max bitrate 8.7 min 7.3Mbps VBR 2 pass with max render quality render enabled
    When I play the m2v file on my computer it looks fine but on the DVD from Encore it is still flickering in the same places
    Is it the better resolution on my monitor that stops me seeing the moire on the pc ?
    What else could I try apart from blurring the offending sections ?
  • Ann Bens
    December 13, 2010 at 9:46 pm
    Try Always Deinterlace in the Field Options for that particular clip.
  • Jon Barrie
    December 14, 2010 at 12:31 am
    It is possible your fields are in the wrong order. A computer won’t show it as all computers monitors are progressive therefore an interlaced video with incorrect field dominance will only show up on a DVD on a tv.
    Try a test where you export a small section of the timeline with an adjustment to the export settings from the field dominance to the other. If it was lower change to upper. Vice versa. You may need to burn annither disc to test. If you have VLC you can set the deinterlacing to off so you can see the interlacing issue to some degree. When the fields are right it looks odd, when they are wring it’s nothing short of horrible and unwatchable. It will only show prominently on moving action.
    – Jon
    Jon Barrie
    aJBprods
    Jon’s YouTube Tutorial Page
    follow Jon with twitter
  • Dave Rogers
    December 14, 2010 at 3:33 pm
    Using VLC with deinterlace set to discard is great tip thank you Jon, I can now at least judge on the pc if I will see a problem on the dvd.
    The clip is actually an image sequence so field order doesnt apply ( I think ?) the images are 1280 x 720. I am saving an output to Ipad so I dont want to apply a slight blur as the sequence as it is looks great on the ipad.
