mpeg2 file encoded program stream with a constant bitrate at 25MB/s
I’m working with FCP 7.0.3, and need to make a
mpeg2 file encoded program stream with a constant bitrate at 25MB/sDo I do this through Compressor after making a MOV on FCP?
I have been given all these options by the people I have to deliver to and am thoroughly confused. Will be very very grateful for help. Apologies for being, and sounding stupid.
Options sent to me:
Standard Definition (SD) Decode
• MPEG 2 SD MP@ML (max 15Mbps), Full D1. NTSC, PAL B, G.
• MPEG 4.2 ASP@L5, Full D1. Rectangular shape video decoding up to 1280X720p30 resolution, support for B Pictures, data partitioning and error resiliency. No global motion compensation.
• MPEG 4.10 (AVC/H.264) BP@L3, MP@L3 and L3.1 (max 5Mbps) up to 720X480 or 720X576 resolution, including FMO and ASO.High Definition (HD) Decode
• MPEG – 2 MP@HL (max 25Mbps) up to 1920X1080i60 or 1280X720p60 resolution.
• MPEG – 4.10 (AVC/H.264) HP@L4.0 and L4.1 (max 15Mbps) up to 1920X1080i60 [1], 1920X1080i50 AVC HD or 1280X720p60, 1280X720p50 resolution.Audio
• Audio Outputs: S/PDIF digital audio (RCA female), Analog stereo audio (L/R RCA).
• Dolby Digital AC-3: Bit rates up to 640kbps. Sample rates of 32, 44.1 and 48KHz. Downmix to 2 channel Dolby Pro Logic.
• MPEG 1 and MPEG 2 Layer I, II and III (MP3) 2.0: Bit rates up to 448kbps (Layer I), 384kbps (Layer II) or 320kbps (Layer III). Sample rates of 16, 22.05, 24, 32, 44.1 and 48KHz. Single channel, dual channel, joint stereo and stereo modes.
• AAC-LC MPEG-2 and MPEG-4:(max 384kbps) Sample rates of 7.35, 8, 11.025, 12, 16, 22.05, 24, 32, 44.1 and 48KHz.Thanks so much, in advance!
SJ
