Activity › Forums › Apple Final Cut Pro Legacy › mpeg2 export in 1920*1080
  • mpeg2 export in 1920*1080
    Posted by Sunpaoz on January 11, 2006 at 11:48 am
    Hi guys,
    first of all, I’d like to excuse me for my bad English which is not my mothertongue ^^
    I’m currently working on Final cut pro 5 on a sequence in 1920*1080 as it is mentioned in the title.
    My problem is that when i try to export it in mpeg2, the sequence is resized in 720*404…
    Is it normal? If not, how can I do for my export to be in its original size?
    Is there a parameter to change somewhere?
    Thanks in advance
    Matthew Brunn replied 20 years, 8 months ago 2 Members · 1 Reply
  • Matthew Brunn
    January 11, 2006 at 7:36 pm
    How are you delivering this video? DVD, computer file, etc. If it is for DVD I have bad news for you.
    Mpeg-2 is SD (Standard Definition) = 720X480. Your HD project will always be scaled down to fit within that. The Mpeg-2 video stream will not handle that amount of information. If you want a true HD picture you’ll need to output to a HD codec like H.264 or DVCPro HD. These will not play on a DVD player. DVD is only Mpeg-2. If you need to export the same thing on your timeline just export to quicktime at current settings. That will make one really big self-contained HD movie.
