Activity › Forums › Compression Techniques › .mpeg with split channels of audio, full stereomix and M&E mix
  • .mpeg with split channels of audio, full stereomix and M&E mix
    Posted by Bradley Greenwell on June 11, 2013 at 10:55 pm
    This scenario is bringing me to the brink of career change.
    I have 28 – 29.97HD PBS programs that need to be converted to this
    File MPEG-2:
    – File format : . mpg
    – Bitrate: 15Mbps (Constant bit rate)
    – Res:720×576 – 4:2:2
    – GOP: 15
    – Frame rate: 25fps
    – Audio: Stereo – 48Khz – 16 bit – 192 or 224 or 384 kbps
    – Ch 1-full mix , Ch2- M/E
    The main problem is getting the split tracks of audio, and maintaining the .mpeg file
    I can convert the video and audio separately and then match them up through quicktime pro, but then i lose the .mpeg and get .mov.
    Im using Final Cut Pro as well.
    Any help would be MUCH APPRECIATED!
    Bradley J.
    Bradley Greenwell replied 13 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
