Activity Forums Apple Final Cut Pro Legacy mpeg streamer query.
  • mpeg streamer query.
    Posted by Trel Winn on August 14, 2009 at 4:03 pm
    I have been sent some DVDs by a client and need to get them into fcp to edit.
    ok so far I have managed to convert the DVD to Mpeg 2
    I am presently trying to convert them to a useable format for fcp to be able to edit them using mpeg streamer. as per these instructions I found
    https://www.foolishpassion.org/vidding-tips/Vidding-101-2.html
    firstly it is taking a very long time to process is this normal?
    and secondly about ten minutes in I got an error message saying
    “write access error” and it just quit.
    I have copied the mpeg 2 files onto an external hardrive and I am also saving the conversion there if that helps.
    Can somone please advise me what Im doing wrong?
    John Fishback replied 17 years, 1 month ago 2 Members · 2 Replies
  • Trel Winn
    August 14, 2009 at 4:06 pm
    oh and the mpeg is about 30-40 minutes long there are 4 of them (documentories)
  • John Fishback
    August 14, 2009 at 4:16 pm
    You shouldn’t convert to mpeg 2 and then convert to an FCP edit codec. Do it in one step in MPEG Streamclip. Open the VOB and export ProRes, DV, DVCPro50, whatever. How is your external drive formatted? If it’s FAT32 you have a 4GB file size limit. If the converted file is bigger than 4GB the export will fail.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
