Activity › Forums › Apple Final Cut Pro Legacy › MPEG Streamclip help…
  • MPEG Streamclip help…
    Posted by Christian Glawe on September 5, 2006 at 2:27 am
    Trying to extract video from a DVD using MPEG Streamclip (yes, legitimate video!)… every 10 seconds or so there is a 1 frame audio dropout, and a skipped video frame a few frames after the audio dropout.
    I suspect it has something to do with the “Fix Timecode Breaks” that it wants to do – it finds around 80 timecode breaks in the DVD stream… although the DVD itself plays perfectly with no dropouts, hits, etc.
    Any ideas?
    David Fortin replied 20 years ago 4 Members · 5 Replies
  • David Roth weiss
    September 5, 2006 at 4:07 am
    Try DVDxDV instead.
  • Jeremy Garchow
    September 5, 2006 at 7:14 pm
    Did you fix the timecode breaks? If not do so.
    Jeremy
  • Christian Glawe
    September 5, 2006 at 7:41 pm
    Yes, I did… program identified around 75-80 timecode breaks, which, interestlngly enough, is probably close to the number of audio dropouts in the resulting .mov
    The DVD I’m extracting from wasn’t authored per se, but recorded on a DVD recorder…
  • Jeremy Garchow
    September 5, 2006 at 8:25 pm
    Hmm. Is it asking you to do all of the VOBs at once or do you do them one at at time? I would try doing them one at a time and see what that gets you. If it asks if you if you want to add all the files say no and continue.
    Jeremy
  • David Fortin
    September 6, 2006 at 12:20 pm
    Streamclip had real problems with DVDs coming from DVD recorders. I never had a problem with Streamclip when the DVDs are authored. But the last 4 or 5 DVDs coming from clients that use recorders would not work.
    I purchased DVDxDV and that program worked on all the ones that Sreamclip didn’t.
    Dual 2.5 G5 {OS 10.4.5}
    4.5 GB RAM
    FCP 5.0.4
    NVIDIA GeForce 6800 Ultra DDL
    DeckLink SP
    ATTO ExpressPCI UL4S
    Medea Video Raid RT320
    Sony UVW-1800
    Pansonic AG-DV2500
    Media Cleaner Pro 6
    Squeeze 4.2 (PC)
    ViewSonic 19″ LCD
    Optiquest 21″ CRT
    Bella EZ Keyboard
