Activity Forums Apple Final Cut Pro Legacy MPEG Streamcip
  • Posted by Suzin Daly on August 5, 2008 at 12:22 pm
    I downloaded streamclip. When I opened it up all I see is a square window with die image with five dots. Is that what I am suppose to see? I do not see any instructions or guidelines. There is a folder that says extras, when opened not much but about save as AVI.
    What am I missing? I know this should be easy, but obviously not for me.
    Chuck Reti replied 17 years, 9 months ago 3 Members · 2 Replies
  • Jim
    August 5, 2008 at 12:43 pm
    Drag video file and drop onto 5 dot square. It will turn back as video is loaded. Go to File and chose format. (ie quicktime) A new window will open. Select from drop down what format (make sure the quality is set to what you require – usually 100%). Hit make movie, give it a name and place to store and go.
    good luck,
    Jim
  • Chuck Reti
    August 5, 2008 at 2:51 pm
    [suzin daly] “I do not see any instructions or guidelines”
    As with most Mac applications, a user guide/help file is available under the “Help” column in the top menu bar.
    Available here is “MPEG Streamclip Guide,” also invoked by Command-?.
