Activity Forums VEGAS Pro MPEG render yields no audio stream?
  • MPEG render yields no audio stream?
    Posted by Bob Belongie on July 23, 2008 at 11:34 pm
    OK, Plug In issue resolved. Next trick. Tried to render a clip as MPEG-2. Video is fine, no audio when played in WMP and Nero ShowTime. Rendered same clip as AVI, then converted to MPEG using AVS Converter, OK audio, but video looks a little squished. I suspect codec issues. Any ideas?
    Bob Belongie replied 18 years, 1 month ago 2 Members · 2 Replies
  • Jeremy Rasnic
    July 24, 2008 at 1:35 pm
    What mpeg template are you utilizing? If you are using the DVD-A template (any of them) they do not include the audio so you do not have to reencode your audio (it should be saved as a seperate stream in AC-3 format). If you are not using the DVD architect templates you can choose to encode the audio with the video or uncheck the box to ensure it doesn’t.
    Also, make sure your track mute property is not selected.
    j razz
  • Bob Belongie
    July 24, 2008 at 3:05 pm
    “ahhhhhhhh” says the grasshopper…
    The difference between a NLE program which holds one’s hand versus one with Great Power (and more opportunity to make mistakes). Humble Thanks, Sensei… 🙂
    BB
