Activity › Forums › VEGAS Pro › mpeg plugin question
  • mpeg plugin question
    Posted by Robert Dupper on June 9, 2005 at 3:09 pm
    hello guys,
    after having edited and delivered the footage as avi, i was asked by my client to convert the avi’s to mpeg-2’s, so they can use it to put on their dvd.
    if i use the standard pal-dv settings that come with the main concept plug-in, will i be save? are there any pitfalls down the line of converting?
    or is it wiser to step to a authoring professional, and let him or her decide how to convert the material?
    thank you for any input.
    i’ll also ask at the authoring forum.
    Robert Dupper replied 21 years, 3 months ago 3 Members · 4 Replies
  • Edward Troxel
    June 9, 2005 at 3:40 pm
    Simply going to File – Render AS – picking MPEG2 as the format and DVD PAL as the preset should work fine. You may need to click “Custom…” and do two things: 1) turn on “Two-Pass” and 2) change the “Average Bitrate” to be appropriate for the length of your video.
    The only other question is audio. That setting will include audio in the MPEG file – compressed audio. They may prefer the audio as either a separate WAV or AC3 file.
    Edward Troxel
    JETDV Scripts
  • Robert Dupper
    June 10, 2005 at 6:39 am
    thank you, edward.
    how should the length of the film influence the bitrate?
  • Allen Zagel
    June 10, 2005 at 9:43 am
    Big time! I recently had a post below……
    https://www.creativecow.net/forum/read_post.php?postid=111795008026616&forumid=24
    …..Titled “getting a video to fit on DVD”. If you render at too high a bitrate, your video won’t fit onto a DVD.
    There’s been many posts here about bitrates and video length. And there’s a lot of Bitrate calculators out there for free that you can use. After you read my post, do a forum search on MPEG-2 bitrates.
    Allen
    My web site features;
    China, China Railways and music.
    https://www.azagel.com
    Video site;
    https://www.asxmediaproductions.com
  • Robert Dupper
    June 10, 2005 at 1:14 pm
    i’ll check it out, thanks.
