Activity Forums Apple Final Cut Pro Legacy Mpeg IMX 625/50 (30mb/s) Workflow in Final cut pro (field error)
  • Mpeg IMX 625/50 (30mb/s) Workflow in Final cut pro (field error)
    Posted by Juha Västi on November 16, 2011 at 9:37 am
    Hey,
    im new with the Mpeg IMX and i have few questions about it. I have two different workflows.
    One
    I get normal Mpeg files from Broadcasting switcher (Tricaster) i convert the clips with Mpeg streamclip to Mpeg IMX 625/50 (30mb/s). After that i edited them With Final cut pro 7 and export them out to MXF file conteiner. Everything is fine.
    Two
    I have music video on casette (Beta) I caputere it with Final cut pro as Dv pal anamorphic. I edit it in Final cut pro timeline. Then i copy the content (Music video) to Mpeg IMX 625/50 (30mb/s)project and export it out as MXF. Now the message i get from our broadcasting servise is that i might have field error on it? now i have tryed De-interlace filter but same thing i have tryed to change the field dominance but i does not help. And some times some files go throug?
    Should i convert the captured video to IMX first and then edit it? the reason why i did not do it was because it adds one more step to my workflow and slows it down.
    I have tryed to ask more details about the Field error but i have got none. They just mail that i might be the reason.
    Juha Västi replied 14 years, 9 months ago 1 Member · 1 Reply
  • Juha Västi
    November 17, 2011 at 7:19 am
    Sorry, found the problem. Someone had changed the (Field dominance) Lower. I brings up another problem that VLC does not show the field error problem and Final cut pro can not playback the MXF-files…so what program you would recomend to monitor the MXF-files?
