Activity Forums VEGAS Pro Mpeg Files – Green , cut short…
  • Mpeg Files – Green , cut short…
    Posted by Dillon Robinson on October 3, 2009 at 11:27 pm
    Hi. I just used the Record function in VLC player while watchin a DVD to collect a bunch of clips.
    However: When I try to drag them into Vegas 9, something happens They drag in fine, as if they are recognized, but they are cut short. Like, less-than-a-second short. And all frames are rendered as solid-green EXCEPT for 2-3 frames each clip. I thought maybe I didn’t record correctly, but watching them in Windows Media Player, I can see that they captured just fine. I don’t want to have to convert 50 clips one-by-one into a different format to test if they work.
    Anyone encounter this problem, or have any tips on how to fix it?
    Dillon Robinson replied 16 years, 11 months ago 3 Members · 8 Replies
  • 8 Replies
  • Dillon Robinson
    October 4, 2009 at 12:49 am
    In addition, now when I try to make a new project with no audio/video tracks there, I get the message: “None of the files dropped in Vegas Pro could be opened”
    Strange considering I thought Vegas had mpeg support. Not sure what type it is, Windows just tells me “.mpg”
  • Theo Van laar
    October 4, 2009 at 9:59 am
    Can you analyze your files with GSpot and place a printscreen of the result?
    Download GSpot:
    https://www.videomontagefaq.nl/attachments/178/GSpot270a.zip
    Theo
  • John Rofrano
    October 4, 2009 at 3:04 pm
    Why are you capturing a DVD with VLC? Why not just import it into Vegas with File | Import | DVD Camcorder Disc and then extract out the parts that you want and discard the rest?
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Dillon Robinson
    October 4, 2009 at 5:47 pm
    Theo: it looks like this. https://img160.imageshack.us/img160/9161/spotcap.jpg
    John: I had no idea such a feature was available. Regardless, I don’t feel like going through the 2-hour movie again to collect these 30 or so clips…. I found converting one of the clips to AVI works just fine. I don’t know what it is about this format that Vegas is being picky about. Then again, Vegas never has worked smoothly in my years with it :/
  • John Rofrano
    October 5, 2009 at 2:47 am
    Look at the GSpot output in your picture under Container (on the left). While VLC named it .mpg the container is DVD “VOB” format which is a delivery format for DVD’s and not an editing format. (essentially VLC just renamed the VOB file to MPG which is not very helpful)
    I would continue to convert them to AVI to make editing easier.
    ~jr
  • John Rofrano
    October 5, 2009 at 10:27 am
    > .VOB IS Mpeg2. The problem is the file has CSS in it. It is scrambled.
    Yes, VOB allows a whole lot more than just MPEG2 video and you are correct, the problem is that there are other things that are allowed in a VOB file that Vegas is not expecting to find in an MPG file (AC3 audio too).
    ~jr
  • Dillon Robinson
    October 5, 2009 at 3:27 pm
    thanks guys, makes sense.
    Seems converting to .avi was my only option anyhow. Works now!
  • Dillon Robinson
    October 5, 2009 at 4:10 pm
    yes, yes it was
