Activity Forums Adobe Premiere Pro MPEG compression adding saturation to export
  • MPEG compression adding saturation to export
    Posted by Mark Coory on April 7, 2014 at 11:16 pm
    Hi
    Im having trouble exporting MPEG 2 for broadcast from Premiere Pro CC.
    Using the Vectorscope I colour correct my timeline to within broadcast luma and saturation limits for PAL 25fps. Then I export that sequence to my broadcast MPEG 2 compression. Then I bring the MPEG back into Premiere pro and notice that certain areas are out of safe range. If I look at that same point in time on my graded sequence the levels are safe.
    The timeline sequence i’m working in is prores 422 1920 50i 8 bit
    my MPEG compression is VBR 1pass, minimum bit rate 7.5 – maximum bit rate 20. 1920 50i
    Premiere pro CC
    Mac 10.9.2
    Thanks in advance.
    Mark Coory replied 12 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
