Activity › Forums › Apple Final Cut Pro Legacy › mpeg choosing right format to convert to work in fcp
  • mpeg choosing right format to convert to work in fcp
    Posted by David Hartman on November 23, 2012 at 8:46 pm
    So i’ve been running around circles for a month now, just trying to get this one video to work. so right now i used my black magic intensity pro to capture 22 min 1280 x 720p 59.9 fps video. only its a 122gb and a avi. i’ve been trying several formats to convert to that should work, but some were lower quality or had audio but no video. i thought i had it at one point but it turned out it was h.264 which fcp doesn’t really like, even though i spent hours waiting for to render and export. when i tried exporting the h.264 it only exported half of the sequence. so last night i tried converting it to prores again , and once again theres audio but no video.
    so my question is this , what settings do i need to punch in to mpeg to get a format that fcp , no loss of quality and most importantly has video. on a side note ,interlace vs de-interlace or neither
    fcp version 7
    Rafael Amador replied 13 years, 10 months ago 2 Members · 4 Replies
  • David Hartman
    November 23, 2012 at 10:40 pm
    no i’m using a capture card on my pc. i captured some game footage, and i want to take what i captured and edit that.
  • Rafael Amador
    November 24, 2012 at 3:16 am
    Your post is confusing, but, by the post subject, I understand that you have some “mpeg”.
    The problem with the audio, I guess, is because they have “MP2” audio and QT/FC don’t take that.
    Try MPGStreamclip which is able to deal with MP2.
    Convert to Prores (unscaled) with Uncompressed 48Khz audio.
    rafael
    http://www.nagavideo.com
  • David Hartman
    November 24, 2012 at 11:16 pm
    ok sorry for the confusion, let me back up. So i have a capture card installed on my pc to capture live footage from my xbox. from that i captured a video file thats an avi. i opened it a plyer called vlc which game the codec info for it
    stream 0
    type :video
    codec: packed YUV 4:2:2, U;Y;V;Y (UYVY)
    resolution: 1280×720
    display resolution: 1280×720
    frame rate: 59.940060
    stream 1
    type: audio
    codec: PCM S16 LE (araw)
    Channels: stereo
    sample rate: 48000 Hz
    bits per sample : 16
    the mpeg i was talking about before is a free convertor program call mpeg stream clip, thats for mac and windows. im using this instead of compressor because it doesn’t import avi. but every time i try to convert it to prores or several other formats that final cut can import, it has no audio but no video. the only one so far that has worked is a codec called h.264, but as im finding out trying to export it from final cut, it has some bugs and doesn’t completely work with final cut. the problem im having with the exporting is that it only exports half of the sequence. and there is no in or out marks.
    by now im just looking for the best quality, and that will work in final cut. the problem will fix it self in a few weeks when my mac tower comes in and can move my capture card in to that , where it will capture in quicktime. also this video is planed to go on youtube.
    so is the best way to get from point A to point B?
  • Rafael Amador
    November 25, 2012 at 2:51 am
    OK, so your problem is that you can’t open those AVI in your mac because you don’t have the necessary QT Components.
    Install “Perian”, and try again with MPGStreamclip.
    rafael
