Activity Forums VEGAS Pro MPEG-2 vs =NTSC DV Widescreen
  • MPEG-2 vs =NTSC DV Widescreen
    Posted by Mike Hite on July 26, 2010 at 10:53 pm
    Well, I finally bought my own copy of vegas pro now that I can actually use it. I originally bought platnium version 9, but when I tried the new version 10 or even vegas pro rendering was choppy.
    Were talking 45 minutes for a 3 min video 720×480 WMV to 720×480 =NTSC DV Widescreen.This only happened on the new black interface.
    This did not ever happen in version 9 with the old grey interface.
    The render was always smooth and fast with version 9c.
    Now that the history is out of the way…
    I finally found a workaround for the broken WMV to =NTSC DV Widescreen with the black interface versions.
    I get choppy rendering of unbelievably slow render times with =NTSC DV Widescreen, but I get absolutely smooth rendering with MPEG-2 NTSC DVD and NTSC YUV Code in AVI format. What gives???
    My question is, which is the better format to render in MPEG-2 or AVI NTSC YUV.
    John Rofrano replied 16 years, 1 month ago 2 Members · 1 Reply
  • John Rofrano
    July 27, 2010 at 2:23 pm
    That depends on what your target device is. What will you do with the rendered video? That will determine the best format to use.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
