Activity › Forums › Apple Final Cut Pro Legacy › MPEG-2 Video Formet Can I see in the Final Cut PRO
Posted by Sulaman Hameed on July 19, 2007 at 10:08 amHello,
Can I Import or Export mpeg-2 Video formet in FCP 5 and Final Cut Express HD Version. I want to see mpeg-2 video in FCP.
and why FCP and Quicktime not support mpeg-2 formet..
I have MacPro G5, 2.66 ghz dual processor, and FCP version 5 and also Final Cut Express HD.Sulaman Hameed
B_ringuet replied 19 years, 1 month ago 4 Members · 3 Replies -
Tom Wolsky
July 19, 2007 at 12:02 pmMPEG-2 is heavily intraframe compressed format designed for delivery of content on DVD or for broadcast transmission. It is not designed nor intended for production. You need to convert your material into a production format that uses interframe compression. The easiest for you with the software you’re using is to convert it to DV.
All the best,
Tom
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” and “Final Cut Express Made Easy” DVDs
Walter Biscardi
July 19, 2007 at 12:06 pm[sulaman Hameed] “I want to see mpeg-2 video in FCP.
and why FCP and Quicktime not support mpeg-2 formet..”You cannot edit with MPEG-2 video in FCP. You must convert it first. Use MPEG Streamclip. It’s free.
MPEG-2 is a finishing format, you should never edit with this format.
Walter Biscardi, Jr.
HD Editorial & Animation for Broadcast and independent productions.All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
Read my blog! https://blogs.creativecow.net/WalterBiscardi
B_ringuet
July 20, 2007 at 3:23 pmHi, am trying to edit ouput in fcp 6 from:
hvx200 Quicktime format (.mov)
and
SDR-S10 MPEG-2 format (.MOD)So far, have used ffmpegX to convert mpeg2 to QT and although it’s playable it’s definitely not sellable (audio out of sync, video pretty bad). Am assuming streamclip is about the same ffmpegX though I haven’t tried it yet. Am thinking about buying a converter called ‘Cinematize 2’ also assuming that because it’s a ‘pay’ product it may somehow do a better job at the conversion. On the other hand it’s possible I don’t know how to drive ffmpegX and by association streamclip.
Appreciate any help.
