Activity Forums Adobe After Effects Mpeg 2 HD
  • Posted by Doug Branch on June 16, 2009 at 6:21 pm
    I have a client thats needs final output of project in Mpeg 2 HD at 30 fps and 20mbps. Since i dont have this option on output of AE what is the best way to convert to this?
    thanks in advance for the help.
    doug
    Erik Waluska replied 17 years, 2 months ago 2 Members · 4 Replies
  • Erik Waluska
    June 16, 2009 at 9:36 pm
    I’m not sure about earlier versions of AE but if you’re on CS3 or higher you will have an HD MPEG2 Blu-Ray output preset. You can find this in the Output Module Settings under the Format drop-down menu. Select “MPEG2 Blu-ray”. Then under Video Output click the Format Options button and adjust your data rate to meet your clients specs.
    -E
  • Doug Branch
    June 17, 2009 at 3:33 am
    i am on ae 7…looks like an upgrade is in the works.
    thanks for the info.
    doug
  • Doug Branch
    June 17, 2009 at 8:37 pm
    eric
    got ae 4 but gives me know options for blu ray…or mpeg 2 hd.
    do i have to have the codecs installed?
  • Erik Waluska
    June 18, 2009 at 6:33 pm
    I’m assuming that by “ae 4” you mean that you’ve upgraded to AE CS4. As far as I know, the codecs, etc. should all be installed when you install the creative suite application. Do you have the suite with Encore, Premiere, etc. or just After Effects by itself? You might check with Adobe and see if the Blu-Ray output is only included with the suite. I don’t really know. Sorry.
    This is where the blu-ray setting should be:
    These are the settings that I normally use:
    -E
