Activity › Forums › Adobe Premiere Pro › MPEG-2 export issue – can’t go over 1088 x1088
  • MPEG-2 export issue – can’t go over 1088 x1088
    Posted by Erika Tsuchiya on June 17, 2017 at 9:23 pm
    I am trying to export 2K planetarium frames to MPEG-2 format but I can’t export over 1088 x 1088 and can’t convert the 2056×2056 mp4 to and mp2 in Encoder either, it defaults back to 1088.
    Is there any way to get around this?
    Thank you.
    Ann Bens replied 9 years, 3 months ago 3 Members · 3 Replies
  • David Roth weiss
    June 17, 2017 at 11:32 pm
    Why are you exporting to MPEG-2? What’s your goal?
    MPEG-2 is most often used to encode DVDs, which must comply with DVD standards, which are limited to SD resolution at only 640×480 or 720×480 in the NTSC world, or, 640×576 and 720×576 in the PAL world.
    David Roth Weiss
    Director/Editor/Colorist & Workflow Consultant
    David Weiss Productions
    Los Angeles
    David is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
  • Erika Tsuchiya
    June 17, 2017 at 11:57 pm
    Thank you for your reply! Yes, I thought it was something like that because I saw MPG2-DVD and Bluray and the resolution constraints would make sense. I believe it is the format that it accepted by the Planetarium software, but perhaps there are other formats that are acceptable that I am unaware of.
    However, I was asked to export MPG2 so I’m trying to find a workaround.
    For now, I have exported H.264 MP4 then using a convertor to change the files into MP2… not sure if that’s very effective or efficient.
    I hope Adobe makes a stand alone batch rendering software… I guess Encoder is supposed to work like that.
  • Ann Bens
    June 18, 2017 at 11:05 am
    Mpeg2 does not go beyond 1920×1080 (1088×1088).
    Maybe you should convince the client to use a more common format which support higher and odd frame dimensions such as mp4.
    You can batch convert with AME.
    Adobe Certified Expert Premiere Pro CS6/CC
    Adobe Community Professional
