Activity Forums Adobe Premiere Pro mpeg-2 duration issues
  • mpeg-2 duration issues
    Posted by Ilya Malov on May 19, 2014 at 7:41 am
    Hello people on Creative Cow!
    This is my first post here. I apologize if there’s a post like this here but I could’t find any.
    So the problem:
    I have 250 frames work area on my timeline in PPro. I need to have widescreen PAL clip 25 fps. When I render this uncompressed, MediaInfo shows exactly 10 second video file with 250 frames containing exactly 10s audio . But coding it to mpeg-2 gives me 10s 56 ms video file containing 248 frames ( 9.920 s) and 10s 56 ms for audio. Why is it so? Our clients need exact time for clips – 10s for 10s and 30 sec for 30 sec – no more no less.
    Could anyone make it clear for me?
    Thank’s in advance
    PS sorry for my english
    Ivan Myles replied 12 years, 3 months ago 2 Members · 1 Reply
  • Ivan Myles
    May 20, 2014 at 2:12 pm
    I have experienced issues with the MPEG2 encoder creating a short time lag with the audio. Import the encoded file into your project and compare to the final sequence. If the problem is confirmed you can offset by trimming/editing the beginning and pulling the audio forward by the same amount as the lag. Re-encode and check exported file in Premiere Pro.
    The loss of two video frames is a bit more perplexing. If the issue is confirmed when you import the encoded file to Premiere Pro, please post a screen capture of the export settings.
