Activity Forums Apple Final Cut Pro Legacy MP4 from PC to final cut
  • Deleted User
    April 29, 2010 at 7:26 am
    Hi Rafael
    Thanks for your reply !
    “For FC you need to un-wrap them or use a plugin. “
    So there is a plugin for FCP that can help ?
    What’s it called ?
    Where do I find it ?
    -Christoffer
    Uses : Sony PMW-EX1, Sony Vegas Pro & SonicFire pro 5,
    Dreams about buying Particle Illusion & Adobe After Effects
  • Rafael Amador
    April 29, 2010 at 1:09 pm
    Hi Scott,
    If I’m not wrong there is no way to work directly with the MP4 files.
    This is possible in VEGAS, because is a SONY application. In PP you can’t do it neither.
    I think the best solution for multi-platform, is to download the files as MFX. You can deal with the FMX in FC using Mfx4Mac.
    No need to convert to Prores or any other codec. native EX footage works very well in FC.
    rafael
    http://www.nagavideo.com
  • Shane Ross
    April 29, 2010 at 2:18 pm
    [Christoffer Thinggaard] “Do you know of a good application that can convert to ProRe”
    If you kept the file structure intact, you could have used the Sony tool, or FCPs Log and Transfer. But without that, you can try CLIPWRAP (there is a demo).
    [Christoffer Thinggaard] “or some year I worked with a guy who used Premiere Pro while I used Vegas , we never had trouble using files in Premiere that Vegas captured or imported (or vice versa”
    OK…those are good examples. So not EVERY NLE, just the ones I work with then.
    [Christoffer Thinggaard] “”In the tapeless world you MUST keep that file structure. ”
    That seem completely unnecessary for me,
    when I can edit the Mp4’s directly with Vegas. “
    If you were ONLY working with Vegas, I can see that mentality. But you aren’t. You are needing to also use that footage in other NLEs, so you need to take that into consideration. Or see if Clipwrap works, and do things your way.
    Shane
Page 2 of 2
