Activity Forums VEGAS Pro .mp4 files wont open anymore (Vegas Pro 14)
  • .mp4 files wont open anymore (Vegas Pro 14)
    Posted by Santeri Hulkko on December 7, 2018 at 12:04 pm
    Hi!
    I shot couple of hundred clips with my Sony A6300 last summer and I started editing them three months ago. Recently I tried to import more clips to the project but Vegas won’t allow it. It wont even play the clips that are already in the timeline.
    I found other posts about similar problems but I haven’t found the solution to this. I have tried to install different Quicktime versions but I cant open my clips in any of them. They still play perfectly fine in VLC and Media Player.
    All of the clips were shot at 4k 100mb/s and 1080p 100mb/s
    Mediainfo:
    __________________
    General
    CompleteName : D:\C0076.MP4
    Format/String : XAVC
    CodecID/String : XAVC (XAVC/mp42/iso2)
    FileSize/String : 177 MiB
    Duration/String : 14 s 515 ms
    OverallBitRate_Mode/String : Variable
    OverallBitRate/String : 102 Mb/s
    Encoded_Date : UTC 2018-07-27 10:42:34
    Tagged_Date : UTC 2018-07-27 10:42:34
    Video
    ID/String : 1
    Format/String : AVC
    Format/Info : Advanced Video Codec
    Format_Profile : High@L5.1
    Format_Settings : CABAC / 2 Ref Frames
    Format_Settings_CABAC/String : Yes
    Format_Settings_RefFrames/String : 2 frames
    CodecID : avc1
    CodecID/Info : Advanced Video Coding
    BitRate/String : 100.0 Mb/s
    Width/String : 3 840 pixels
    Height/String : 2 160 pixels
    DisplayAspectRatio/String : 16:9
    FrameRate_Mode/String : Constant
    FrameRate/String : 29.970 (30000/1001) FPS
    ColorSpace : YUV
    ChromaSubsampling/String : 4:2:0
    BitDepth/String : 8 bits
    ScanType/String : Progressive
    Bits-(Pixel*Frame) : 0.402
    StreamSize/String : 174 MiB (98%)
    colour_range : Full
    Codec configuration box : avcC
    Audio
    ID/String : 2
    Format/String : PCM
    Format_Settings : Big / Signed
    CodecID : twos
    BitRate_Mode/String : Constant
    BitRate/String : 1 536 kb/s
    Channel(s)/String : 2 channels
    SamplingRate/String : 48.0 kHz
    BitDepth/String : 16 bits
    StreamSize/String : 2.66 MiB (2%)
    Other
    Type : meta
    Graham Bernard replied 7 years, 9 months ago 2 Members · 3 Replies
  • Graham Bernard
    December 7, 2018 at 12:38 pm
    [Santeri Hulkko] “Recently I tried to import more clips to the project but Vegas won’t allow it. “
    And…
    [Santeri Hulkko] “They still play perfectly fine in VLC and Media Player.”
    Kinda point towards Vegas going sour. Any Windows updates? Many things could have happened in the interim. Try a reinstall of Vegas?
    However, been using MP4 this morning. Anyway, MP4 is only a wrapper.
    * Grazie
  • Santeri Hulkko
    December 7, 2018 at 5:34 pm
    Thank you! I was afraid to reinstall Vegas because of all the plugins and shit but now it works perfectly fine.
  • Graham Bernard
    December 7, 2018 at 5:42 pm
    [Santeri Hulkko] “Thank you!”
    Yeah, you’re very welcome. Factory resets or a reinstall often cure much.
    * Grazie
