Activity › Forums › Adobe Premiere Pro › mp4 clip
mp4 clip
Posted by Mark Webb on April 20, 2018 at 10:24 pmI have a clip which is 1440X1080 4:3 mp4 now when i import in premiere its not displaying correctly
when i play it in vlc it plays correctly and at the 4:3 with the barswhen in premiere its out of proportion
what sequence settings should i be using?how do i set it to the right ratio 4:3?
Mark Webb replied 8 years, 5 months ago 2 Members · 4 Replies -
Shane Ross
April 20, 2018 at 11:44 pmSo this isn’t an anamorphic file? Not meant to be stretched out to 16:9? Because 4:3 HD is a non-standard format (well, now more standard due to Instagram)…so Premiere might not be set up for it. You can create a custom sequence that matches that format by dragging the clip onto the NEW SEQUENCE icon in the Browser.
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Mark Webb
April 20, 2018 at 11:54 pmnot sure about it being anamorphic file
here is the info on the clip
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42 (isom/avc1/mp42)
File size : 636 MiB
Duration : 8 min 57 s
Overall bit rate : 9 920 kb/s
Movie_More : CarDV-TURNKEY
Encoded date : UTC 2017-01-04 08:28:00
Tagged date : UTC 2017-01-04 08:28:00
Origin : NVT-IMVideo
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.1
Format settings : CABAC / 1 Ref Frames
Format settings, CABAC : Yes
Format settings, RefFrames : 1 frame
Format settings, GOP : M=1, N=15
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Bit rate : 9 829 kb/s
Width : 1 440 pixels
Height : 1 080 pixels
Display aspect ratio : 4:3
Frame rate mode : Constant
Frame rate : 20.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.316
Stream size : 630 MiB (99%)
Language : English
Tagged date : UTC 2017-01-04 08:28:00 -
Mark Webb
April 21, 2018 at 2:49 amI have scaled it to about 75% as Dave LaRonde recommend and its look alot better now
