Activity › Forums › VEGAS Pro › MP3 in an avi file
  • MP3 in an avi file
    Posted by Dr. nagy Ferenc on January 5, 2008 at 4:29 pm
    Hello,
    I’m trying to render an avi file with an mp3 audio track with Vegas Pro 8.0 but the best I can choose is 56 kbps (which is rubbish).
    If I only render the mp3 file (file format is set to: MP3 Audio (*.mp3)), it works fine. Here is the dialog:
    Free Image Hosting at www.ImageShack.us
    How can I access this dialog box while making an avi file?
    Thanks in advance.
    Dr. nagy Ferenc replied 18 years, 9 months ago 2 Members · 2 Replies
  • Laszlo Kovacs
    January 5, 2008 at 8:55 pm
    I had similar problem years ago, the solution was to install the FHG Radium mp3 codec, and choose that one.
    That was long ago, so i can’t remember where I downloaded it from; google for it, or contact me private if you want me to post it to you (kovacsltmeister at gmail dot com).
    Regards
    K.L.
  • Dr. nagy Ferenc
    January 6, 2008 at 9:07 am
    I installed the FHG Radium MP3 codec v1.263 and now there are two “MPEG Layer-3” audio codecs and one of them contains higher bitrates as well. However, if I choose anything higher than 56 kbps, it says “An error occured while opening a codec.”. If the bitrate is <= 56 kbps, then it's fine. The real solution would be to use Sony's built-in mp3 codec but I don't know how to access that. (I could render the video and the audio separately and then put together with VirtualDub but that's just stupid, there should be a smarter workaround.)
