Activity Forums Adobe After Effects MP Rendering to image sequences ends early
  • MP Rendering to image sequences ends early
    Posted by Riccardo Sinti on March 19, 2015 at 8:00 pm
    AE CC 2014, OSX 10.8.3, iMac 16gb RAM
    I have 30+ comps I need to render to SGI sequences.
    With a non MP render it takes about 3mins but with MP on it takes about 1min15secs. Great!
    these are my MP settings:
    Installed RAM: 16gb
    RAM for other apps: 5gb
    Installed CPUs: 8
    CPUs reserved for other apps: 4
    RAM allocation per BKG CPU: 2gb
    Actual CPUs that will be used: 4
    Well, I tried to use BG render pro to render locally and then automatically copy to a server, but some of the sequences (1440fr) would end at random frames and move on to the next comp without any error message. This was no good so I tried rendering straight from the render que and get same results.
    Out of 32 comps 5 would end after 300frames and move on to the next.
    Any ideas why this is happening? Can adjusting my settings help? Is this a bug?
    Thanks for any insight.
    Walter Soyka replied 11 years, 5 months ago 2 Members · 1 Reply
  • Walter Soyka
    March 20, 2015 at 9:57 am
    [Riccardo Sinti] “Well, I tried to use BG render pro to render locally and then automatically copy to a server, but some of the sequences (1440fr) would end at random frames and move on to the next comp without any error message. This was no good so I tried rendering straight from the render que and get same results. Out of 32 comps 5 would end after 300frames and move on to the next.”
    Do those five comps have 300-frame work areas [link] set?
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
