Activity Forums Maxon Cinema 4D Moving this object
  • Jim Scott
    October 3, 2021 at 12:11 am
    To group objects put them all in a null, either by selecting them all and using the keyboard shortcut ALT + G, or by adding a null to the scene and dragging them all into it as children. You can then move the null to move all the objects together.
  • Jim Scott
    October 3, 2021 at 6:55 pm
    I should have also mentioned that you could select all the objects, and then with the cursor over one of the selected objects, right click and select “Group Objects,” which is where you will also see the keyboard shortcut listed.
