Activity Forums Maxon Cinema 4D Moving Texture Showing In Gouraud Shading Not In Rendering
  • Moving Texture Showing In Gouraud Shading Not In Rendering
    Posted by Gerrit Velthuis on May 6, 2011 at 4:15 pm
    I have to make clear (in a schematic way) that the outside surface of a rubber component has to be lubricated with vaseline.
    Therefor I made a texture with a bitmap that has the color of the rubber (brown) with a white band over it.
    The texture does exactly what I want when I animate the offset U value in the texture tag. (see attached screendump) . . . . . . at least . . . . in Goureaud shading mode (see small strip at the bottom).
    In “Interactive Render Region” and final rendering however, nothing is to be seen.
    What have I overlooked or done wrong ?
    2308_gvrendertest.jpg.zip
    Gerrit Velthuis replied 15 years, 4 months ago 1 Member · 1 Reply
  • Gerrit Velthuis
    May 6, 2011 at 4:45 pm
    Problem Solved:
    In the texturetag window I had set the “side” value to “front”.
    Changing this setting to “both” made the effect show up, I don’t know why, but it works.
