Activity › Forums › VEGAS Pro › Moving text across the screen
  • Moving text across the screen
    Posted by Rob Lindsay on November 26, 2018 at 11:15 pm
    i am trying to move text in the text generator from outside the screen on the right across the screen to disappear off the left side. Sounds simple, but I can’t see why Vegas isnt doing that. It only renders a portion of the movement, not the start or finish.
    i’ve attached a screen shot
    <img src="https://i1.creativecow.net/u/317565/image_20181126230656_1.png" />
    Thanks for your help.
    Vegas 13.545
    Dell Windows 10
    Intel 6700 quad CPU
    16 Gigs RAM
    3 Gig GPU
    Rob Lindsay replied 7 years, 10 months ago 2 Members · 3 Replies
  • Aaron Star
    November 27, 2018 at 4:48 am
    #1: Use the Animation setting: Scroll Left – Center
    The duration of the effect is sometimes hard to find the beginning and end. Keep moving the start and end point until you see the 1st letter, then the last letter leave. Adjust the duration in the text box for speed, and fade the ends if you want. You may have to increase the size of the text box, so the text is not destroyed on the left on screen but rather off screen.
    #2: Alternatively use the “Pan and Crop” tool on the titles& text FX, and use the keyframe animation tools at the bottom of the window. The move only tool selection on the bottom of theleft icons is useful to limit movement to only left and right. If you do not know what keyframing is, you need to learn it some time.
  • Rob Lindsay
    November 27, 2018 at 5:51 am
    Thank you, Aaron — I will try these!
    Vegas 13.545
    Dell Windows 10
    Intel 6700 quad CPU
    16 Gigs RAM
    3 Gig GPU
  • Rob Lindsay
    November 28, 2018 at 2:03 am
    Thanks again, Aaron. I got the titles to move using the Text Generator. I’ve used key frames before, and did again. By fumbling thru them and somehow getting it the way I wanted :).
    I still don’t understand how to use them and the video you shared wasn’t very clear to me either.
    But it’s done and i appreciate your help!
    Vegas 13.545
    Dell Windows 10
    Intel 6700 quad CPU
    16 Gigs RAM
    3 Gig GPU
