Activity Forums Maxon Cinema 4D Moving tangent arms independently? “C4D 11 Workshop” question
  • Moving tangent arms independently? “C4D 11 Workshop” question
    Posted by Robert Mcgunnigle on June 8, 2009 at 8:40 pm
    Okay…this is a total newbie question. I’ve searched this forum, consulted the ‘help’ function in C4D, checked the manual, and haven’t been able to figure out the answer!
    I’m currently working out of the “C4D 11 Workshop” book and I’m stuck on a particular step in one of the introductory projects. Specifically, it’s page 13 (creating a Maglite), where it says to press the “Shift” key while clicking on one of the tangent arms on either side of a spline point in order to independently move the arms to create a gradual curvature in the spline. I’m following the instructions to the letter, but it doesn’t work for some reason. HELP!
    Rob
    There’s no shelf-life on creativity.
    Robert Crossley replied 17 years, 1 month ago 4 Members · 6 Replies
  • Arndt Von koenigsmarck
    June 8, 2009 at 9:00 pm
    Hi Rob,
    you are using a Bezier spline and you can see the tangents of selected spline points?
    Holding down the Shift key together with the left mouse button while moving a tangent should break it.
    Kind regards,
    Arndt von Koenigsmarck
    https://www.vreel-3d.de
    https://www.vonkoenigsmarck.de
  • Robert Mcgunnigle
    Arndt,
    Thank you for the prompt response! I tried your suggestion, but with no luck!
    Here’s a screenshot of what I’m talking about. Hopefully, it will clarify things a bit.
    Rob
  • Adam Trachtenberg
    June 8, 2009 at 11:32 pm
    You have to have the move tool activated.
    June 9, 2009 at 7:39 am
    Yes, Adam made a good point. You have to use the Move tool if you want to move anything in the viewport. The screenshot shows, that you are using the Live Selection tool still.
    Kind regards,
  • Robert Mcgunnigle
    June 10, 2009 at 2:35 am
    Okay! That did the trick! Thanks, guys…I appreciate the help! It’s always the small, stupid stuff that trips you up!
    Rob
  • Robert Crossley
    July 11, 2009 at 4:08 pm
    Rob
    Sorry to interupt your thread, but you may be of assistance in solving an Adobe Photoshop software problem that I have.
    I get this runtime error: (with the details)
    AppName: photoshop.exe AppVer: 10.0.1.0 ModName: scriptingsupport.8li
    ModVer: 10.0.0.0 Offset: 0015eebd
    The only this I haven’t tried is a full unistallation.
    If you think you might be of brief assistance could you reply to
    RobertCrossley@onetel.com.
    Much appreicated
    Rob
