Activity › Forums › Adobe After Effects › Moving pulses simulation
  • Moving pulses simulation
    Posted by Stuart Brontman on April 21, 2005 at 9:16 pm
    Does anyone have a suggestion on how to simulate a series of pulses moving along a line in one direction. I’m trying to create a mood of electricity moving down a wire. The pulses will have to do a sharp 90+ degree turn. This is all being done on top of an existing photograph.
    Thanks in advance for any suggestions.
    Stuart
    Stuart Brontman replied 21 years, 5 months ago 3 Members · 3 Replies
  • Steve Roberts
    April 21, 2005 at 10:29 pm
    Draw a mask that follows the desired path, then apply Effect>Render>Vegas. Tweak to suit.
    Steve
  • Mike Clasby
    This might work for you.
    Dup the layer, and put the Turbulent Displace effect on the top layer, animating the Offset(Turbulence). Mask the top layer to isolate the pulses to the power line area.
    At the 90’s you will probably need to split the layers and add a new mask to the line.
    You can always run the Bulge Effect along the line similarly.
  • Stuart Brontman
    April 22, 2005 at 1:24 am
    Thanks for the suggestions. I’ll give them a try.
    Stuart
