Activity Forums Apple Motion Moving on photos stutter problem
  • Moving on photos stutter problem
    Posted by Cindy Hill on January 16, 2010 at 5:29 pm
    I am working on a documentary and am incorporating Motion to create my photo moves. I have two basic questions.
    1) Are there advantages to adding a 3D camera then the Move behavior or is is just as effective to add a behavior without the camera, assuming I am doing basic pans, tilts and zooms?
    2) I am working in FCP 6.0.6 Sequence-DVCPRO HD 960×720, 23.98 editing timebase with a DVCPRO HD 60 compressor setting. When I render my photo moves in Motion as Animation 23.98, I seem to get stuttering on the move.
    Any idea what might be causing this? I am using the Best setting on the rendering but am not selecting field rendering. Is this a possible cause?
    Thanks for your advice.
    Cindy Hill replied 16 years, 8 months ago 2 Members · 2 Replies
  • Bill Nelson
    January 16, 2010 at 5:44 pm
    Regarding your camera question, if you can achieve the results you need w/o the camera, then I’d do that.
    Your thought concerning the stuttering issue would be an easy test… export a second or two with field rendering checked and check your results. You just might have it there.
  • Cindy Hill
    January 16, 2010 at 5:53 pm
    Thanks, Bill. I think I may have rendered some of my previous Motion projects with the wrong timecode base and hence the odd stuttering problem in FCP. Duh!!
