Moving objet along single axis
Hello, I will try to explain the problem like this.
I create a null then rotate it along H 30 degrese or so. Then when i move the null along z axis it goes where i want it to go but in the attribute editor it uses both x and z axis to compensate for the rotation. And then I have 2 curves in the animation editor to deal with. Is there a way to rotate object and move it along it’s own local axis so i can have one curve for my direction?
Thanks in advance!
