Activity › Forums › Adobe After Effects › Moving objects on path
  • Hector Vera
    May 23, 2024 at 6:01 pm
    Found a video that can help you on how you can move objects within After Effects to your needs. Hope this helps: https://www.youtube.com/watch?v=rP-Gn87NKzo
    It looks like you will need to create a path for the object by drawing lines and assigning keyframes to know how fast or slow you wish for it to move!
  • Virendra Chandekar
    May 23, 2024 at 8:55 pm
    Thank you for your reply Hector Vera. Greatly appreciated.
    But the problem with this solution is that the line that I am using as an object to move on a path, will turn without bending. If you notice in the reference video, the path has a sharp turn. Here the white line will just rotate as attached to the path. Not bend with the path.
    Thank you
