Activity Forums Zaxwerks Moving object’s axis??
  • Moving object’s axis??
    Posted by Jennifer Occhicone on June 1, 2009 at 3:44 pm
    Hello,
    I am trying to make a door swing open, How do i move that objects axis point from the center of the object to the edge of that object so it swings like a door in zaxwerks? we are using zaxwerks in AE.
    jen
    Edward Wu replied 17 years, 2 months ago 2 Members · 1 Reply
  • Edward Wu
    June 1, 2009 at 11:37 pm
    Hi Jennifer,
    Assuming you are using 3D Invigorator Pro, you can set up the door pivot by creating the same door twice, and lay them side by side. Make sure the doors are in the same set, and when the program calculates the center point of the set, the pivot point will be at the center of the 2 doors and basically be at the “hinge” location. If you need to, choose the “Recenter Pivot” command in the “Set” pulldown menu located in the AE Effect Controls panel. Then, you can go back into the 3D Invigorator interface and make one of the doors invisible, or delete it from the set.
    When you rotate the door, the pivot point should be at the door hinge.
    Best,
    Edward
