Activity › Forums › Adobe After Effects › Moving objects around a mask path
  • Moving objects around a mask path
    Posted by Garrett Perkins on February 4, 2016 at 5:27 pm
    I have four objects positioned at various points around a circular mask path. I want them all to move around the mask path. I understand how to copy the path on to the position of a null (control) object and then parent one of the objects to the controller. However if I parent all of the objects to the null they don’t move around the same path. Basically I want each object’s start position to be it’s respective position along the path. What expression do i need to write to make that work?
    Garrett
    John Cuevas replied 10 years, 8 months ago 2 Members · 1 Reply
  • John Cuevas
    February 4, 2016 at 5:55 pm
    Instead of moving null around the mask path, place the null in the center of your 4 objects, parent the objects to the null, then just rotate the null.
    Johnny Cuevas, Editor
    ThinkCK
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
