Activity Forums Adobe After Effects Expressions Moving object to music on y-axis only?
  • Moving object to music on y-axis only?
    Posted by Rasmus Jelbo on June 10, 2021 at 1:41 pm
    Hi all,
    I’d like to make a loudspeaker bounce up and down to the music, but when I pigwip ‘position’ to the sound channel it bounces on both axis. Is there an expression, which will exclude movement on the x-axis?
    Best Regards,
    Rasmus
    Andy Kiernan replied 5 years, 2 months ago 2 Members · 1 Reply
  • Andy Kiernan
    June 10, 2021 at 2:22 pm
    I think the easiest way is to right-click the layer and set ‘separate dimensions’, so that x and y are individually keyframable, then you can pickwhip only the Y to the sound keys
