Activity Forums VEGAS Pro Moving multiple tracks forward
  • Moving multiple tracks forward
    Posted by Ryan Collins on October 16, 2010 at 9:49 pm
    Hi, I’m quite new to Sony Vegas Pro 9, and have recently put together a video project with multiple audio and video tracks. Upon almost finishing the project, I realized that I forgot to add an introduction with titles. I was wondering if there was a way to insert a segment(in which to put a title) in the beginning of the project without manually moving all of the video clips and various effects and motion key frames forward along the timeline. Thank you for your time.
    -Ryan Collins
    Roy Van der westen replied 15 years, 11 months ago 3 Members · 2 Replies
  • Mike Kujbida
    October 17, 2010 at 3:19 am
    Method #1.
    Place the cursor at the very beginning of your timeline.
    Insert – Time, enter the desired amount and then drop your title into the empty space.
    Method #2.
    Enable Auto Ripple.
    The easiest way is with the toolbar icon.
    Make sure the dropdown menu is set to “All Tracks, Markers and Regions”.
    Move the first clip to the right the desired amount and everything else will automatically follow.
    Disable Auto Ripple.
    Drop your title into the empty space.
  • Roy Van der westen
    October 17, 2010 at 9:24 pm
    Select the first clip (left top), holding shift key, click on the last clip (bottom right). With all these selected, you can easily drag all the video clips.
    -RvdW
    If you have a problem, if no one else can help, and if you can find me, maybe you can hire me
