Activity › Forums › Apple Motion › Moving Mat Issue
  • Moving Mat Issue
    Posted by Sean Lloyd on March 18, 2010 at 4:41 am
    Hello Cow Crew,
    I am having a minor problem that is turning into a major issue. I am working on a moving shot that dollies in and pans over to the action. It is an exterior shot and is night. I have created a moving mat that I have been using to have some Motion made train smoke appear as if it is traveling behind the building. As well, I replaced the sky with a moon that I have had to track to the shot.
    Everything has been going well except for the fact that a portion of the mat seems to bounce a little bit against a portion of the building, not much, but enough to ruin the effect. I have tried going over that section but it seems very hard to fix.
    My question is…is there a better way to to do this effect? For instance, some kind of garbage mat where I could use color key to key out the sky or create a mat from. I’m sure if I try to key out the sky without some sort of boundary I’ll pick up a lot of blacks from the building.
    This is one of those instances where I have come too far to turn around. Meaning that I have already put many hours into this and feel that I am close, but don’t know how to proceed.
    Any suggestions would be greatly appreciated. I am on Motion 3.
    Peace and thanks…Ian
    Sean Lloyd replied 16 years, 6 months ago 5 Members · 25 Replies
  • 25 Replies
Page 1 of 3
