Activity Forums Adobe Premiere Pro moving from PP CS2 to CS3 Master Suite
  • moving from PP CS2 to CS3 Master Suite
    Posted by Martha Daniel on April 27, 2008 at 3:40 pm
    I am getting ready to install new CS3 Master Suite that will replace my exisiting Premier Pro CS2 (as well as other applications in the suite)on my PC.
    Is there anything that I should know about or prepare…or be wary of…. prior to installing this new Master Suite?
    I am also going to be installing an upgrade to Premier Pro CS3 from exisiting CS2 on another PC machine. Anything there I should know about??
    Any hints or suggestions would be greatly appreciated.
    Thank you in advance!
    Martha Daniel
    DownEastDocumentaries.com
    Rocky Mount, NC
    Steven L. gotz replied 18 years, 5 months ago 2 Members · 1 Reply
  • Steven L. gotz
    April 28, 2008 at 9:22 pm
    You should be OK. If you have room to leave CS2 on your system along with CS3, it would be a great idea. As far as video goes, it is better to finish projects in the application that created them.
    Steven
    https://www.stevengotz.com
