Activity Forums Apple Motion Moving from Motion 3 to 5
  • Moving from Motion 3 to 5
    Posted by Marc Lucas on October 30, 2011 at 9:49 pm
    Got FCS2 on both my home and work Macs. I have Motion 5 installed on a separate drive but want to make the transition to Motion 5 on all machines. What are the caveats with the move…
    1. Do I uninstall Motion 3 and just replace with Motion 5?
    2. Can Motion 5 open Motion 3 projects (which is my biggest worry because I have a ton of Motion 3 projects that I need to access)
    Marc Lucas replied 14 years, 11 months ago 2 Members · 2 Replies
  • Mark Spencer
    October 31, 2011 at 1:59 pm
    You don’t need to uninstall Motion 3 in order to install Motion 5.
    You should be able to open your Motion 3 projects in Motion 5 – but you can’t go the other way.
    You can’t import Motion 5 projects into FCP7, nor can you roundtrip from FCP7 to Motion 5.
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
  • Marc Lucas
    October 31, 2011 at 2:36 pm
    Thanks mark
    Just was concerned that the two apps (Motion 3 & 5) would work ok on the same system really. I knew about the round tripping thats not a problem right now. I’m just slowly transitioning from FCS2 to FCP X Motion 5 and I have a ton of old projects that I need to access so being cautious and making sure my system(s) keep running normally.
