Activity Forums VEGAS Pro moving envelope keyframes
  • moving envelope keyframes
    Posted by Adam Rose esq. on October 12, 2006 at 3:59 pm
    am trying to change volume keyframes for the following situation:
    beginning & end of audio track are fine, volume-wise. BUT the middle section needs to be lowered uniformly, with all it’s keyframes.
    When I select the central keyframes and try to lower them, they move in percentage-fashion, it seems.
    one option, I suppose, would be to duplicate the track, remove central audio from first track, and leave it on duplicate, then lower track volume for the duplicate.
    any other ideas?
    Edward Troxel replied 19 years, 11 months ago 2 Members · 1 Reply
  • Edward Troxel
    October 12, 2006 at 4:35 pm
    What if you use another volume envelope but on the “Master” bus track? Or add another bus, point that track to the new bus, and add a volume envelope there?
    Edward Troxel
    JETDV Scripts
