Moving edits in Premiere
I have switched over to Premiere from Final Cut, and cannot for the life of me figure out this issue.
In Final Cut, when an edit is selected, if you push the ‘up’ or ‘down’ arrow key it will move the playhead up one edit or down one edit on the timeline, and it will also move the selection of the edit up or down one edit, so that the edit that is selected is the same the edit the playhead is on. In Premiere, if I have an edit selected (with the roll tool, for example) and I push the ‘up’ or ‘down’ key, it moves the playhead, but the originally highlighted edit stays highlighted. So what I’m asking is how do you move the selection up or down one edit, so that I can just use the arrow keys to adjust edits rather than having to keep clicking each edit as I go along. I have messed around with all of the shortcut keys and have searched endlessly online it seems. If anyone knows this, thanks so much in advance!
