Activity › Forums › Adobe Encore DVD › Moving Buttons
  • Moving Buttons
    Posted by René Martin on August 12, 2012 at 10:46 pm
    I created a short menuvideo for a DVD in After Effects and I directly put the text for the menu buttons in there. Inside the video loop the camara rotates slightly around the actual menu.
    Now I wanted to give those buttons a highlight effect in photoshop but the problem is that the text for the button is floating around because of the camera movement.
    My question: is there any way to add some kind of movement to buttons in encore/photoshop? or does it work when I use a dynamic link to an after effects project?
    Eric Pautsch replied 14 years, 1 month ago 2 Members · 1 Reply
  • Eric Pautsch
    August 13, 2012 at 2:29 am
    Technically it’s possible because button highlights are simply subtitle so it’s possible to author in button that appear to move but not with Encore. This is only possibly on high end authoring tools like Scenarist
    The Spiderman title has moving buttons
