Activity › Forums › Adobe After Effects › moving background
  • Todd Kopriva
    April 8, 2013 at 9:18 pm
    It’s hard for us to know how to help you when you aren’t telling us what you’ve tried so far and exactly what problems you’re having.
    After Effects team blog
  • John Nelson
    April 9, 2013 at 12:43 am
    Sorry for being so non-descriptive. I think I might have figured it out, though.
    What I’m trying to do is to have a stationery (animated) cartoon car and driver with a moving background. Think a long strip of drawings moving in the background from right to left; trees, clouds, buildings, etc. as the foreground car travels along; wheels turning, bouncing up and down.
    I ran a test by making the background comp twice as long as the comp for the car and nesting it. Don’t know if that is the correct/easiest method but it worked. If you have an easier method I would like to hear it. The moving background will be made up using the paint effect, drawing the clouds, etc.
    Thanks for the quick input.
    https://www.omproductions.net
  • Todd Kopriva
    April 9, 2013 at 12:53 am
    Play with the Offset effect. It can be useful for the kind of thing that you describe.
  • John Nelson
    April 9, 2013 at 1:06 am
    Thanks again Todd. I’ll give it a try and report back.
  • Chris Brett
    April 9, 2013 at 8:30 am
    — you could also try doing a search for multi-planing —-chris —
  • John Nelson
    April 9, 2013 at 9:17 pm
    After pondering a solution I decided to make a long photoshop layer and move it across the screen from right to left. Worked perfectly.
    Thanks for all the input.
