Activity › Forums › Avid Media Composer › moving avid project..
  • moving avid project..
    Posted by Crister B on February 23, 2006 at 10:43 am
    I am working on a project at home on a mac and I want to bring it to work onto a pc. Is this possible? Its only one and a halv minute video so it would fitt on a dvd. I want to move the whole project so I can keep woring at work/ How is this done? Is it? I appriciate any feedback. Thanks
    Geraint Pari huws replied 20 years, 7 months ago 2 Members · 3 Replies
  • Geraint Pari huws
    February 23, 2006 at 1:38 pm
    it depends!
    do you need to move the media?
    audio is easy, you can either export an omf(consolidate first if necessary) at home and suck this back in at work, it will rebuild your sequence with the media.
    vision can be a little more tricky, it depends exactly what systems you’re using, where did the vision material originate?
  • Crister B
    February 23, 2006 at 2:02 pm
    my media is on the computer at home.. i guess I would have to bring the whole raw material aswell with me then? no way to just bring the needed media? thanks again
  • Geraint Pari huws
    February 23, 2006 at 2:06 pm
    again it depends on format – dv25 will move cross platform I think,
    if you imported the media rather than capturing then take the origional files across on dvd along with a medialess vision omf, then you can just batch import you vision, but watch your import setting at work…?
