Activity › Forums › Adobe After Effects › Moving an object along a growing line
  • Moving an object along a growing line
    Posted by Sarah Bott on February 7, 2018 at 3:59 pm
    Hi everyone,
    I’m wondering if you can help me simplify my project.
    I’ve built an animation that has a blinking dot traveling from location to location on a map. As the dot travels, a path appears showing where the dot has been.
    Right now I have the line animating separate from the dot, but each the customer asks to retime things it is very time consuming since I have to retime the line separate from the dot. I’m wondering if there is a way I can control the growing line along with the dot so I’m only adjusting one set of keyframes when I need to make edits.
    Thanks for any help!
    Walter Soyka replied 8 years, 7 months ago 3 Members · 2 Replies
