Activity Forums VEGAS Pro Moving a group of clips all together
  • Moving a group of clips all together
    Posted by Dáithí Cinnsealach on April 26, 2016 at 2:44 pm
    So when I delete a clip I have to move the clips to the right manualy one by one, which takes a long time. Is there any way to highlight those clips and move them to the left?
    Graham Bernard replied 10 years ago 4 Members · 3 Replies
  • Aaron Star
    April 26, 2016 at 7:09 pm
    I would read up on Ripple Edit in the help file and see if that is what you need.
  • Wayne Waag
    April 26, 2016 at 7:50 pm
    So when I delete a clip I have to move the clips to the right manually one by one,
    You can also go the first clip after the one deleted, right-click and then click on “Select Events to End” and then drag them all at once.
    However, if you’re doing simple cuts editing with not much else on your timeline, then use of ripple edit as Aaron suggested is even easier and faster.
    wwaag
  • Graham Bernard
    May 7, 2016 at 2:58 am
    I use Ripple Edit all the time for this. BUT, it is a very powerful tool indeed. Do make sure you switch it off after use.
    * Grazie
