Activity Forums Adobe Premiere Pro Moving a clip without changing sequence duration
  • Moving a clip without changing sequence duration
    Posted by Jo Gali on January 22, 2019 at 8:26 pm
    Is there a way to move a clip left and right in without changing sequence duration? Say I want to move a clip in between a cut but I don’t want to add time to my sequence. Would I be able to do this in one move via keyboard shortcuts? This move is similar to what you would do on AVID with the yellow arrows.
    Jeff Pulera replied 7 years, 7 months ago 3 Members · 2 Replies
  • John Pale
    January 24, 2019 at 4:27 am
    Use the slide tool
  • Jeff Pulera
    January 24, 2019 at 10:45 pm
    I think if you just hold down the CTRL key first (on PC, don’t know Mac) then you can drag the clip how you want. Make sure Snap is enabled (looks like magnet)
    Jeff Pulera
    Safe Harbor Computers
