Activity Forums Maxon Cinema 4D Moving a C3D project from one directory to another
  • Moving a C3D project from one directory to another
    Posted by Hawkowski on April 27, 2006 at 8:43 am
    I do keep all the models, textures etc of my C4D scene in one directory. In the final form of my C4D scene, some of the models and textures are no more required.
    How can I export the final scene to a new directory so that ONLY used etities are copied?
    Would you recommend from your experience a better practice of organizing, storing models, textures, etc?
    Roberto Hawkowski
    Lennart Wåhlin replied 20 years, 4 months ago 2 Members · 1 Reply
  • Lennart Wåhlin
    April 27, 2006 at 6:49 pm
    First in the MaterialManager go “Remove Unused textures/materials”
    Then use “SaveProject As..” The scene file .c4d and a tex folder (with the scenes textures) will be saved in a folder to a location of your choice.
    It is the same way as I do when NET rendering. I then SaveProjectAs straigh into the admin folder of NET Server.
    Cheers
    Lennart
