Activity Forums Adobe After Effects Moving “3D” objects into new comp
  • Moving “3D” objects into new comp
    Posted by Pete Lewis on January 10, 2009 at 2:41 pm
    If I’ve created a simulated 3D object (for example, anything with Particular, following this tutorial: https://www.forgingfire.com/site/video-tutorials-after-effects/3D.asp), is it possible to move it into a new comp and animate it with the new comp’s camera and it remain 3D? The only way I can figure to do it is to make the comps the same size (which for certain things is not possible)and copy the camera’s movements from the new comp into the first comp. Hopefully there’s a better way. Thanks for any help.
    Pete Lewis replied 17 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
