Activity › Forums › Adobe After Effects › Movie Theater Effect
  • John Cuevas
    December 28, 2012 at 2:20 pm
    Here’s one recipe(this effect could be accomplished a lot of different ways, put add adjustment layer over you footage and add a levels effect that simulates the brightness of the screen. Change the adjustment layers transfer mode(I used Luminosity). Lastly add a wiggle effect to the adjustment layers opacity.
    wiggle(4,45)
    I used your picture and before I started I really brought down the initial brightness using a curves effect. Here’s a quick example project to look at, if it helps:
    5131_theatrecs5.5.aep.zip
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Jennifer Adams
    December 28, 2012 at 3:03 pm
    Wow, thanks so much Johnny, you’re the best! It looks fantastic! 🙂
  • John Cuevas
    December 30, 2012 at 4:33 am
    Glad I could help.
    Thinkck.com
